Marubeni Citizen-Cincom Sales Engineer James Sabatino took a few minutes at Eastec 2023 to showcase the Cincom L32 XII Swiss-type CNC automatic lathe that features nine cutting axes and an automatic toolchanger.
- automatic toolchanger
- lathe
lathe
- toolchanger
toolchanger
