EMAG VL 1 TWIN – Highly Productive Simultaneous Machining
This twin-spindle turning machine is perfect for the manufacturing of workpieces up to 3 inches in diameter. With two main spindles in one machining area, the VL 1 TWIN can simultaneously machine two identical workpieces – leading to a massive increase in output quantities and decreased cost per piece.
November 1, 2018
The diameter and length of both components can be measured and then corrected independently of one another. In addition, the machine also has a direct position measuring system and a linear motor in the X-axis to ensure the highest machining quality and maximum productivity. Visit our website for more information.
n
  • turning machine
    Any machine that rotates a workpiece while feeding a cutting tool into it. See lathe.
  • linear motor
    Functionally the same as a rotary motor in a machine tool, a linear motor can be thought of as a standard permanent-magnet, rotary-style motor slit axially to the center and then p…
