Episode 103: Cylindrical grinding relief
Episode 103: grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. Th…" title="Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. Th…" aria-label="Glossary: cylindrical grinding">Cylindrical grinding relief
Dr. Jeffrey Badger provides a simple, if not pretty, solution to a nasty cylindrical grinding problem — when the side of a grinding wheel meets a flat surface. Watch the 103rd episode of the Grinding Doc video series.
Dr. Jeffrey Badger provides a simple, if not pretty, solution to a nasty grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. Th…" title="Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. Th…" aria-label="Glossary: cylindrical grinding">cylindrical grinding problem — when the side of a grinding wheel meets a flat surface. Watch the 103rd episode of the Grinding Doc video series.
About Jeffrey Badger, Ph.D., and the Grinding Doc Video Series: Thanks to his work as an independent grinding consultant and the author of the "Ask the Grinding Doc" column in Cutting Tool Engineering magazine, Badger routinely receives questions about grinding from shops all over the world. Through the magazine column and this video series, he provides shops with the insight and guidance they seek.
For more information about the Grinding Doc, visit his website here.
n
