Iscar Quick-D-Mill: One tool, Multiple Functions, Maximum Efficiency.
Iscar's Quick-D-Mill combines the functions of Drilling and Milling into one cutter for Maximum Machining Efficiency.
January 2, 2026
Iscar's Quick-D-Mill combines the functions of Drilling and Milling into one cutter for Maximum Machining Efficiency. Available in .625", .750", 1" and 1.250" diameters. This advanced cutter uses a versatile insert design allowing 2 center cutting edges and 2 peripheral cutting edges on the same insert. The insert's pocket features a robust and durable design incorporating Dovetail Clamping to ensure High Process Reliability. Pinpoint Coolant Jets direct coolant right to the cutting edge providing better chip evacuation which reduces heat load and increases tool life. Available in straight shank or Iscar's Multi-Master connection for maximum flexibility. Get yours today!
