Maximize Shoulder Milling Precision with TungForceRec
Accelerate your milling performance with Tungaloy's TungForce-Rec series, engineered for precision, stability, and maximum productivity.
Accelerate your milling performance with Tungaloy's TungForce-Rec series, engineered for precision, stability, and maximum productivity. This versatile miniature shoulder milling cutter features a unique V-shaped insert bottom and advanced clamping system that securely locks the insert in place, delivering exceptional accuracy and extended tool life—especially in small pockets and slots. With five insert sizes supporting cuts from 0.158" up to 0.650", TungForce-Rec adapts easily from fine finishing to aggressive milling. The result is reliable machining, excellent surface finishes, and consistency across a wide range of applications. https://www.youtube.com/shorts/n8ZeXJGT3Wc
