Meet the new Okuma GENOS M460V-5AX
Published Date
June 05, 2018 - 02:45:pm
The purposefully affordable GENOS M460V-5AX is a full simultaneous 5-axis machine specifically designed for high-precision manufacturing from the most demanding materials. The Okuma 5-axis machine you’ve always wanted is now within reach. Robust performance in a smaller footprint. With its innovative double-column structure, the GENOS M460V-5AX is a next-generation vertical machining center. While its full 5-axis simultaneous control system and thermal countermeasures grant you the ability to cut soft or hard materials, it’s the unique build features that make the M460V-5AX such a machining powerhouse.
  • machining center
    machining center
