MIKRON features Crazydrill Crosspilot solid carbide drills
The CRAZYDRILL Crosspilot is one of the very successful tools in the CRAZYDRILL line of high precision, high performance, solid carbide drills of Mikron. It is used to drill inclined holes and does the traditional operation of Flat Milling, NC Spot Drilling and the actual drilling with a twist drill in two steps instead of three.
February 22, 2014
The CRAZYDRILL Crosspilot is one of the very successful tools in the CRAZYDRILL line of high precision, high performance, solid carbide drills of Mikron. It is used to drill inclined holes and does the traditional operation of Flat Milling, NC Spot Drilling and the actual drilling with a twist drill in two steps instead of three. The benefits are: High positioning accuracy, excellent alignment accuracy and the elimination of one tool. It has a very robust design, a special tip geometry (170°) and guarantees perfect centering for the subsequent drilling operation. The tool is available from dia. 0.394" (0.40mm) to 0.5906" (6.00mm) from Mikron Corp. Monroe, CT.
n
  • twist drill
    Most common type of drill, having two or more cutting edges, and having helical grooves adjacent thereto for the passage of chips and for admitting coolant to the cutting edges. Tw…
