Mil-Tec High Feed cutter ideal for 40-taper CNCs
Published Date
February 22, 2014 - 09:45:am
Mil-Tec's High Feed cutter has positive geometry and uses ground carbide inserts that make it ideal for 40-taper CNCs. Using standard NP geometry, the HFC High Feed has high value and is said to be perfect for job shops.
  • feed
