New 4TEX Drill Delivers Superior Chip Formation in Difficult Applications
The new 4TEX® drill is engineered to deliver optimal chip formation and evacuation and provide higher penetration rates than standard twist drills for light duty machines.
February 14, 2019
The new 4TEX® drill is engineered to deliver optimal chip formation and evacuation and provide higher penetration rates than standard twist drills for light duty machines. This indexable insert drill excels in applications with interrupted cuts or when drilling on angled surfaces. The design increases core strength, improving hole size and straightness. Dual twisted coolant outlets improve penetration rates by enhancing coolant flow and generating superior chip formation and evacuation. The 4TEX is also ideal for making shallow 2xD, 3xD, and 4xD holes in the 0.472" – 1.850" (12mm - 47mm) range.
For more information visit us at
https://www.alliedmachine.com/Home.aspx
Or email us at [email protected] for more details.
n
  • indexable insert
    Replaceable tool that clamps into a tool body, drill, mill or other cutter body designed to accommodate inserts. Most inserts are made of cemented carbide. Often they are coated wi…
