With the new versions of the T2711 and T2712 thread milling cutters, Walter offers an indexable insert solution for small blind-hole and through-hole threads (≤ 2.5 × DN) in dimensions of M16, M18 and UNC3/4. It can be used in almost any material. Flutes prevent the tool being deflected by the chips produced, while the internal coolant ensures reliable chip removal. This makes the tool ideal for high cutting speeds and feeds per tooth.
For more information about the T2711 and T2712 thread milling cutters, visit the Walter website here.
- blind-hole
blind-hole
- coolant
- flutes
flutes
- indexable insert
indexable insert
- through-hole
through-hole
