Okuma showcases new standard in 5-axis machining
Take a look at the GENOS M460V-5AX with one of Okuma's machining center product specialists. This 5-axis vertical machining center is specifically designed to manufacture high-precision parts.
Take a look at the GENOS M460V-5AX (https://www.okuma.com/genos-m460v-5ax) with one of Okuma's machining center product specialists. This 5-axis vertical machining center is specifically designed to manufacture high-precision parts. It delivers impressive metal removal rates in a compact design. And with a solid double-column structure, full 5-axis simultaneous control, and thermal stability performance, you'll have the ability to easily cut a variety of materials. If you're interested in increasing productivity and profitability—without breaking the bank—then meet the GENOS M460V-5AX. Welcome to Open Possibilities.
For more information visit https://www.okuma.com/genos-m460v-5ax
n
