POW•R•FEED M935
POW•R•FEED M935
Unlock faster cycle times, outstanding metal removal rates without clogging, and fewer tool changes with the POW•R•FEED M935 end mill from IMCO.
Building on the trusted performance of the M9 family, the new POW•R•FEED M935 takes it even further. These next-generation end mills are designed with advanced cutting geometries and high-performance coatings to boost speed, eliminate obstacles, and help you get more done with greater efficiency.
Ready to take your machining to the next level? See what the M935 can do for you.
Learn more at imcousa.com!
