Reduce Setup Time & Maintain High Accuracy
Ditch the traditional work holding setups on conventional T-slot tables that are time-consuming and prone to errors. Upgrade to today's modern alternative to the conventional T-slot tables and vices - Lyndex-Nikken's Zero Point clamping system and modular clamping rail system. This modular work holding has the flexibility and diversity to hold any workpiece while maintaining high accuracy.
Since only one clamping stud is required, set-up times are drastically reduced, and machine capacity is increased. The modular clamping rail system has the flexibility you need for any clamping width and multiple clamping options with just one system due to endlessly connectable clamping rails.
Using the Lyndex-Nikken Zero Point clamping system and modular clamping rail system can result in a reduction of setup times by up to 90% and 330 hours of additional production time per year.
