See Tapmatic’s DeBurr-Z Floating Holder for CNC Deburring
Eliminate tedious hand work and deburr the work piece on your CNC machine for more consistent and controlled results. The DeBurr-Z floats in both the compression and extension direction allowing the cutting tool to follow the top edges or underside edges of the work piece even when these are not clearly defined.
June 1, 2025
Eliminate tedious hand work and deburr the work piece on your CNC machine for more consistent and controlled results. The DeBurr-Z floats in both the compression and extension direction allowing the cutting tool to follow the top edges or underside edges of the work piece even when these are not clearly defined. This makes programming easy. The force is equally and simultaneously adjustable for compression and extension. Spherical and angular burs are available depending on your application. The DeBurr-Z may also be used for engraving. It allows a faster approach to the workpiece and the ability to mark curved surfaces. Tapmatic offers combination deburring/engraving cutting tools.
