Tungaloy small insert lines
Tungaloy going small. Small inserts, outstanding productivity. Featuring the AddDoFeed for maximum speed and efficiency at minimum size, Tung-Tri for small shoulder milling operations with cost-efficient inserts and outstanding chatter stability ...
Tungaloy going small. Small inserts, outstanding productivity. Featuring the AddDoFeed for maximum speed and efficiency at minimum size, Tung-Tri for small shoulder milling operations with cost-efficient inserts and outstanding chatter stability, TungForce-Rec versatile shoulder milling cutter with unique V-shaped bottom for maximum productivity, AddInternalCut four-edged insert for small internal grooving operations with a minimum diameter of 0.438", and AddMeisterDrill — the world's smallest exchangeable head drill series with 0.004" increments.
n
