Tungaloy Unveils Size 18 Inserts for TungForceRec Series!
Tungaloy expands its TungForceRec shoulder milling cutter series with size 18 inserts, featuring a reverse-positive design and V-bottom structure for enhanced durability, rigidity, and reduced cutting resistance. Tungaloy's TungForceRec delivers reliable, cost-effective solutions for versatile machining applications.
February 1, 2025
Tungaloy expands its TungForceRec series with a larger Size 18 insert, offering enhanced versatility through four insert sizes for broader milling applications. This high-performance shoulder milling solution ensures exceptional stability, reliability, and efficiency. The Size 18 insert delivers unmatched strength, a max depth of cut of 0.650", and tool diameters ranging from 1.000" to 6.000". Its unique V-shaped insert bottom and innovative clamping system boost durability and rigidity while reducing cutting resistance, ideal for machining small pockets and slots. With reduced vibration, extended tool life, and a compact design, TungForceRec excels in aerospace, medical, and die & mold industries.
https://tungaloy.com/us/press-release/tungforce-rec_expansion_18size_inserts/
  • depth of cut
