Vollmer VHybrid 360 for grinding & eroding
Published Date
July 16, 2020 - 04:15:pm
Do you want to grind carbide tools and erode PCD tools with high productivity? The new VHybrid 360 from Vollmer of America Corp. combines the strengths of an innovative grinding machine and a proven, powerful erosion machine. The VHybrid 360 allows users to switch between the two functions in no time. A range of automation options are available.
  • grinding
  • grinding machine
    grinding machine
