FC-200D, FC-300D, FC-500D and FC-200CNC Tool Grinders
April 27, 2016
Rush offers the Models FC-200D, FC-300D, FC-500D and FC-200CNC polycrystalline tool grinders, which allow for economical manufacturing and regrinding of PCD, CVD, PCBN, carbide and HSS tools. These machines grind angles and radii on standard and special turning and milling inserts, boring tools, milling cutters, grooving tools, reamers and special tools. The rigid construction with a 3-hp, variable-speed grinding spindle provides for vibration-free grinding and fast stock removal.
All models feature a unique video optical system with 15-120x (zoom) magnification and a black and white video monitor. This system provides a higher magnification and/or a larger field of view than most machine-mounted optical comparator systems, according to the company. In addition, the video camera moves with the worktable for easy setup and for inspection during and after grinding.
The Model FC-500D is a large, versatile machine. In addition to all of the capabilities of the FC-200D and FC-300D, the FC-500D features vertical grinding spindle travel, a wheel travel range of 500mm and an oscillation stroke of 70mm. The Model FC-500D is also designed for grinding reamers, drills, endmills and multistep form tools.
  • boring
    boring
  • chemical vapor deposition ( CVD)
  • gang cutting ( milling)
  • grinding
  • grooving
    grooving
  • high-speed steels ( HSS)
  • milling
  • polycrystalline cubic boron nitride ( PCBN)
    Cutting tool material consisting of polycrystalline cubic boron nitride with a metallic or ceramic binder. PCBN is available either as a tip brazed to a carbide insert carrier or as a solid insert. Primarily used for cutting hardened ferrous alloys.
  • turning
Additional Products from Rush Machinery
Designed for cutting tool manufacturers and carbide rod processors, this production machine can significantly increase your production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines. It's easy-to-use CNC controls and touch screen operator interface…
The Truing Parameters Calculator is the result of a 3-year collaboration between Rush Machinery, the International Grinding Institute, and Dr. Jeffrey Badger, the ‘Grinding Doc’. Rush Machinery commissioned the project that was later presented at the 2008 CIRP General Assembly in Tokyo by…
The CH-CM0406 Cut Pre-Point Chamfer Machine makes carbide blanks that are ready for tool grinding. The machine converts blank carbide rods into tool blanks. It is suitable for cutting tool manufacturers that want to make tools from a blank that is already pre-pointed and chamfered. The machine is…
Rush Machinery offers the Model FC-350EX and Model FC-350W wheel truing and dressing machines, designed for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs.
Rush Machinery is offering the CH-CM0203 CNC Carbide Rod Chamfer Machine for chamfering blanks for carbide and HSS cutting tools. The machine comes equipped with a large-capacity magazine, an automatic loader, a flood coolant system, 2-axis servomotor and servo amplifier, and fully automatic CNC.
Rush Machinery offers the new Rush Easy-Cut XL semiautomatic carbide cut-off machine for quick and easy cutting of carbide flat stock up to 2”x4” or rod and tool ends with diameters between 1/8” to 2”.
The 2 Rod “Auto-Cut” CNC Carbide Cut-Off Machine automatically cuts carbide rod into precision lengths. This production machine, designed for cutting tool manufacturers and carbide rod processors, has a large-capacity magazine and an automatic loader to provide hours of unattended operation.
The BMT-150M On-Machine Balancing Kit from Rush Machinery for balancing wheels and wheel packs on truers or grinding machines. The kit comes with everything you need to get started.
Rush Machinery Inc.'s Drill and Tool Grinders have helped thousands lower their holemaking costs through higher precision, faster production, less down time and reduced tool inventory.
Ideal for tool manufacturers, grinding wheel manufacturers, and production grinding facilities, the economical Model FC-250W Diamond/CBN Wheel Truing and Dressing Machine from Rush Machinery Inc. is for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple…
