Truing Parameters Calculator
March 30, 2023
Online Truing Parameters Calculator for Truing and Dressing Diamond and CBN Wheels
Rush Machinery introduces the Truing Parameters Calculator for truing and dressing Diamond and CBN Wheels. The Truing Parameters Calculator recommends the proper dressing wheels and wheel speeds to optimize the truing and dressing process. It is now available on our website here: https://rushmachinery.com/truing-parameters-calculator/.
A demo will be available at the Eastec trade show May 16–18, 2023 in West Springfield, MA at the Eastern States Exposition. Rush Machinery can be found in Booth #1121.
The Truing Parameters Calculator is the result of a 3-year collaboration between Rush Machinery, the International Grinding Institute, and Dr. Jeffrey Badger, the ‘Grinding Doc’. Rush Machinery commissioned the project that was later presented at the 2008 CIRP General Assembly in Tokyo by Dražumerič, Badger, Klement, and Krajnik titled “Truing of Diamond Wheels–Geometry, Kinematics and Removal Mechanisms,” published in the CIRP Annals, volume 57, pages 345-348.
  • cubic boron nitride ( CBN)
  • dressing
    dressing
  • grinding
  • truing
    truing
    Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
Additional Products from Rush Machinery
The CH-CM0406 Cut Pre-Point Chamfer Machine makes carbide blanks that are ready for tool grinding. The machine converts blank carbide rods into tool blanks. It is suitable for cutting tool manufacturers that want to make tools from a blank that is already pre-pointed and chamfered. The machine is…
Rush Machinery offers the Model FC-350EX and Model FC-350W wheel truing and dressing machines, designed for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs.
Rush Machinery is offering the CH-CM0203 CNC Carbide Rod Chamfer Machine for chamfering blanks for carbide and HSS cutting tools. The machine comes equipped with a large-capacity magazine, an automatic loader, a flood coolant system, 2-axis servomotor and servo amplifier, and fully automatic CNC.
The 2 Rod “Auto-Cut” CNC Carbide Cut-Off Machine automatically cuts carbide rod into precision lengths. This production machine, designed for cutting tool manufacturers and carbide rod processors, has a large-capacity magazine and an automatic loader to provide hours of unattended operation.
Rush Machinery offers the new Rush Easy-Cut XL semiautomatic carbide cut-off machine for quick and easy cutting of carbide flat stock up to 2”x4” or rod and tool ends with diameters between 1/8” to 2”.
The BMT-150M On-Machine Balancing Kit from Rush Machinery for balancing wheels and wheel packs on truers or grinding machines. The kit comes with everything you need to get started.
Rush offers the Models FC-200D, FC-300D, FC-500D and FC-200CNC polycrystalline tool grinders, which allow for economical manufacturing and regrinding of PCD, CVD, PCBN, carbide and HSS tools. These machines grind angles and radii on standard and special turning and milling inserts, boring tools,…
Rush Machinery Inc.'s Drill and Tool Grinders have helped thousands lower their holemaking costs through higher precision, faster production, less down time and reduced tool inventory.
Ideal for tool manufacturers, grinding wheel manufacturers, and production grinding facilities, the economical Model FC-250W Diamond/CBN Wheel Truing and Dressing Machine from Rush Machinery Inc. is for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple…
The Rush Grinding Fluid Filtration system offers an optional magnetic separator prefilter and collection unit to handle high volume swarf applications with ease.
