TwistSFeed Drill Family
March 25, 2021
3-Flute Replaceable Tip Drills
Ingersoll’s new TwistSFeed drill family features a 3-flute quick-change tip with an upgraded clamping mechanism designed to maximize productivity. Unlike conventional 3-flute solid carbide drills, TwistSFeed utilizes a unique, self-centering point to ensure optimal performance, precision and stability for all applications.
TwistSFeed reduces costs by improving tool life as well as achieving higher productivity due to multiple flutes along with new IN2205 coating designed for steel and cast iron applications. The clamping mechanism allows for the simple replacement of drill tips as well as accommodating multiple tip diameters per drill body facilitating economical stock management for end users.
Tips are available in diameters from .6299"-8288" and bodies include 3xD and 5xd L:D ratios.
  • flutes
    flutes
Additional Products from Ingersoll Cutting Tools
High axial rake reduces cutting loads and promotes smooth machining.
In addition to operating on narrow grooving on typical CNC lathes, the new V-shaped TDMV inserts are suitable with a wide range of applications on Swiss automatic lathes, with a concentration on miniature product machining. The V-shaped TDMV insert line is a multi-purpose option and the optimal…
Tangentially mounted inserts allow for smooth uniform chip formation at high feed rates. The patented end-station fully supports the insert for reliable operation and unobstructed chip evacuation. End station inserts are available from .031 to .250 corner radius with zero cutter body modifications.
hi-feed milling performance for machining of miniature components and smaller part features. NanoFeed is a 20° hi-feed indexable insert design that will replace smaller diameter solid carbide end mills in many applications and offer great economy! Inserts have been designed with pressed-in coolant…
The insert pocket is designed with dovetailed seating over a large contact area, which extends cutting edge life, cutter body life cycle, stability, and support under the most aggressive cutting conditions. Inserts are offered in 2 styles: economical pressed complete and a precision ground profile.
Key features include four insert sizes, grades for all materials, three different cutting-edge preparation options, super strong radius high feed insert geometry, fine and coarse pitch cutters. The 4mm, 6mm, 9mm and 11mm inserts offer depth of cut ranges of .5mm, 1mm, 1.5mm and 2mm, respectively.
CeraSFeed features two unique double-sided indexable insert styles: LNXF09 and TNXN12. LNXF09 offers a 1.5mm depth of cut and 4 cutting edges. TNXN12 offers a 2.5mm depth of cut and 6 cutting edges. Both inserts are offered in grade IN76N, a highly engineered SiAlON ceramic grade having excellent…
It represents a highly productive alternative to conventional turning where 80° & 35° corner inserts are fed in the same direction, and instead utilizes all 4 directions available on conventional 2 axis lathe (+Z, -Z, +X, -X) to maximize material removal.  The double-sided positive SuperTurnZ…
Ingersoll Cutting Tools offers dovetail with a positive-rake-angular advantage and 6-flute productivity performance.
Ingersoll Cutting Tools announced the next step in the evolution of the fixed-pocket, indexable BTA drill head.
