U-tec Flexible Adapter System
August 01, 2015
Heimatec announces immediate availability of its popular U-tec flexible adapter system on all right-angle heads in the company's line. Models are now available for most popular lines of machine tools in the North American market, according to company President Preben Hansen. The company plans to include its U-tec adapter system on all angle heads, going forward, according to Hansen. He notes this development will especially provide the system's rigidity and quick-change capabilities to users doing deep hole drilling with extended tools.
U-tec is the company's patented flexible tool adapter system that allows a standard ER output live tool to accept various adapters for different applications. This allows users the ability to have quick changeover of tools on almost any lathe or mill, using a single live tool, without having to commit to a quick-change system on the initial purchase. A facemill adapter, for example, can be quickly positioned into the standard holder, without the need for a completely new base being installed. This significantly reduces inventory costs as well as changeover time, for the busy shop.
The U-tec system, according to Preben Hansen, represents a real improvement in lathe and mill/turn tooling design. "U-tec allows great user flexibility, while a polygonal drive system ensures extremely high power transmission stability and faster set-up with absolutely no loss in performance or accuracy, because the live tool base remains in position and only the adapter and collet get swapped out."
He went on to explain the unique collet nuts on the U-tec system have internal threading for rigid mounting and that this new tool adapter system enables the actual cutting tool to be brought into closer proximity to the bearing, thus further improving performance in use. This benefit results from the short and compact tool length design. Internal coolant up to 2000 psi (140 bar) is provided as standard.
Every adapter in the U-tec system, complete with any necessary clamping nuts and adapters for arbor, Weldon, CAT 40 and CAT 50, is now available in shell mill, face mill, ER extension, side lock, shrink fit, hydraulic and blank styles. U-tec angle heads are compatible with most automatic tool changers, feature 360º manual positioning and include torque arms and a stop block. Torque rated up to 150 Nm (110 ft-lb).
  • arbor
    arbor
  • collet
    collet
  • coolant
  • facemill
    facemill
    Milling cutter for cutting flat surfaces.
  • lathe
    lathe
  • milling machine ( mill)
  • threading
    threading
Additional Products from Platinum Tooling Technologies Inc.
REV static broaching tools are for use on CNC lathes with or without Y-axis. They offer a patented eccentric bushing which eliminates alignment errors for machines without a Y-axis. The tools have a sturdy two-piece construction and are ideal for smaller runs. They are designed for use in boring…
The QUICK® product spectrum offers innovative solutions for diverse knurling technology applications. For both form knurling and cut knurling, QUICK® fulfills the most stringent quality standards and masters difficult tasks. Knurling tools are available for use on a wide range of workpiece…
Rineck offers standard and custom shrink fit tool holders with various connections including CAT, HSK, BT, SK, PSC and straight shank extensions. In addition, ER shrink fit collets are available. For added rigidity, flange or dual contact holders are available for CAT and BT tapers.  A clamping…
The REV motorized broaching tool is designed for use on live tool lathes. Single machine set-up eliminates the need for secondary operation or outsourcing. REV tools are ideal for high production runs, offer easy installation and fast processing time. These tools are designed for maximum rigidity,…
The u-tec patented changing system allows a standard ER output live tool to accept various adapters for different applications. This allows users the ability to have quick changeover of tools on almost any lathe or mill, using a single tool, without having to commit to a quick-change system on the…
Platinum Tooling, the importer and distributor of live tools, angle heads, marking tools, Swiss tools and multi-spindle tools manufactured by various global suppliers, is now the North American importer of the QUICK® knurling and marking tools from Hommel & Keller.
According to Preben Hansen, president of Platinum Tooling Technologies, Inc., “We are now carrying a substantial inventory of live tools for our customers’ machines.  It represents a significant financial and warehouse space commitment that we have made to support the North American machine tool…
Platinum Tooling announced that it has an extensive line of Heimatec tooling available for the new Haas BMT turret. Platinum Tooling is the master importer of Heimatec tools for North America.
Platinum Tooling, an importer of live tools, angle heads, marking tools, Swiss tools and multiple-spindle tools manufactured by various global suppliers, is now importing Henninger Speed Increasers for North America. The announcement was made by company president, Preben Hansen, at the company…
Heimatec Inc. announces immediate availability of marking and cleaning tools from its European partner Andreas Maier, under the AMF brand. The announcement was made by the president of Heimatec Inc., Preben Hansen. “This development brings additional products to our current customers and responds…
