The Guardian™ Works when Other Filtration Systems Fail
Successful coolant filtration requires three components (1) particulate removal, (2) tramp-oil removal, and (3) coolant concentration control. The Guardian™ Coolant Recycling System incorporates all three elements—not just pieces—for maximum coolant life. This combination makes it the most efficient option for centralized recycling of metalworking cutting fluids.
May 31, 2019
Successful coolant filtration requires three components (1) particulate removal, (2) tramp-oil removal, and (3) coolant concentration control. The Guardian™ Coolant Recycling System incorporates all three elements—not just pieces—for maximum coolant life. This combination makes it the most efficient option for centralized recycling of metalworking cutting fluids. If your current process is labor intensive, requires a lot of downtime for sump maintenance, or lacks the capacity to handle all the fluid, its time for a change. In this video, see how the PRAB Guardian recycles your spent cutting fluids to significantly decrease coolant spend and eliminate tramp-oil issues.
For more information visit us at PRAB Guardian Coolant Recycling System
n
PRAB.COM
Scroll for the next video
