A Critical Application in Medical Molding
Plastic medical parts are sometimes machined, but frequently they are produced using plastic injection molding instead.
March 30, 2026By Alan Richter
View print ads from this spread
Review the ads on this magazine spread to continue reading. Each ad takes two seconds; a two-page ad counts once.
Advertisers on this magazine spread
Print placements on this magazine spread
ing instead. SyBridge Technolo- forms in the real world.”
A Southern California-based manufacturer produces injection
mold tooling for drug delivery, diagnostics and surgical devices. By Alan Richter is right doesn’t mean the plastic part will be. The molded part is P lastic medical parts are never a perfect replica of the cav- sometimes machined, but ity. At the end of the day, the goal frequently they are pro- isn’t steel that measures right, it’s a.
A Southern California-based manufacturer produces injection mold tooling for drug delivery, diagnostics and surgical devices. By Alan Richter is right doesn’t mean the plastic part will be. The molded part is P lastic medical parts are never a perfect replica of the cav- sometimes machined, but ity. At the end of the day, the goal frequently they are pro- isn’t steel that measures right, it’s a duced using plastic injection mold- part that meets tolerance and per- ing instead. SyBridge Technolo- forms in the real world.”
Print page 23
Visit ing instead. SyBridge Technolo- forms in the real world.” View this placement in the issue record
Plastic medical parts are sometimes machined, but frequently they are produced using plastic injection molding instead. SyBridge Technologies is one company that manufactures the injection mold tooling to mass produce plastic medical parts, as well as plastic parts for other markets such as automotive. “Most of our molds are class 101 molds that are guaranteed to produce one million shots,” said Aaron Liefveld, general manager of SyBridge Technologies, which is headquartered in Rancho Cucamonga, California. The company was founded in 2019 through the acquisition of 15 manufacturers across North America, Europe and Asia.
Liefveld noted that the company has two separate divisions: life science, which includes medical and health care, and mobility, which deals mainly in automotive. “Completely different worlds as you can imagine.” Various plastics are available and injection-molded medical parts come in a host of shapes and sizes.
According to SyBridge, the company’s precision engineering ensures consistent part quality and extended mold life. By knowing the plastic and part shape, SyBridge begins the moldmaking process with the design for manufacturing (DFM) methodology, said Daniel Schoelmberger, SyBridge’s business unit director. “Knowing the material and the part, there are often changes that we suggest, knowing that this would make a better part, with better quality and often at a better price.” That process might involve changing part features that are difficult to extract from the mold without major actions or part damage, he added.
“Just because the steel is right doesn’t mean the plastic part will be. The molded part is never a perfect replica of the cavity. At the end of the day, the goal isn’t steel that measures right, it’s a part that meets tolerance and performs in the real world.” The company reports that it embeds manufacturability into the heart of its injection mold tooling design process, proactively identifying and resolving issues early on.
In addition to DFM, SyBridge’s design for excellence approach considers all critical factors, ensuring tooling is optimized for performance, reliability and cost-effectiveness. Schoelmberger said dimensions that are critical for fit and function — and what the part is supposed to do in the application — are particularly targeted, and those dimensions typically tie in with a Cpk number, a statistical measure used to assess a manufacturing process’s ability to produce output within specified limits. For example, a Cpk of 1.33 corresponds to a process where 99.994% of products fall within specification limits and is more information about the author For more information about SyBridge Technologies, call 833-824-1116 or visit www.
sybridge.com. Alan Richter, a 40-year veteran journalist, has spent the last 25 years covering the metalworking industry for Cutting Tool Engineering and currently serves as its editor-at-large. Contact him at alanr@ctemedia.com.
ctemag.com/mfgaxis.com Medical.indd 21 21
3/19/26 10:09 AM
considered acceptable in most industries because it provides an effective balance between process capability and defect rates. “When you achieve the required Cpk, you’ve proven the process is stable and capable, which means you can reliably produce in-spec parts for years to come from that mold.” The vast majority of the molds SyBridge produces, said Liefveld, are made of the “highest end” 420 stainless steel that is heat treated to achieve a hardness of 50 to 54 HRC. “We do build some aluminum molds for rapid prototyping,” he noted, “but that is not our specialty. That makes up 2% of the molds that we build.”
Tight Tolerances
Using CNC machine tools, EDMs and other machining equipment, SyBridge cuts the steel workpieces to the needed shapes, Liefveld explained. Besides building a mold that must achieve the specified Cpk value, it must meet the required tolerances. The shutoffs where two pieces of steel come together to close the plastic part off, for example, have a tolerance of ±0.0051 mm (±0.0002").
To measure machined dimensions, the moldmaker uses dial indicators with a 0.0025 mm (0.0001") resolution and two Hexagon CMMs that are accurate to within ±0.00127 mm (±0.00005").
Liefveld said it’s important to note that cavity and core inserts are assembled into a mold base, and the two halves of the mold base must match. The company designs parting line interlocks, or straight interlocks, into the base to keep the alignment proper, and that way all of the cavity and core blocks have individual alignment built into the cavity and core blocks themselves. The objective is to get a dual alignment to make sure that everything stays concentric. “Machining them is difficult, and then we have to hold everything as closely as possible to print.
You’re not building a Frisbee mold.” Another CMM is used to check the plastic parts that a mold produces, he said. SyBridge performs extended trials to verify that the plastic parts coming out of a mold’s cavities meet all requirements. “Once the mold is complete, we put it in the press, shoot it and get the first article of the parts that come out.
We take a look at the parts, and we’ll make a modification at that time to help these parts run. It’s continuous improvement even ongoing during the original build.” SyBridge’s primary customer base includes both medical OEMs and global contract manufacturers, according to Schoelmberger. Many OEMs operate their own in-house, or captive, molding capabilities, while contract manufacturers produce on their behalf. “In both cases,” he said, “we’re supporting critical programs that ultimately serve the same end-use medical applications.”
Complex Mold Actions
SyBridge reports that it engineers molds with servo-driven systems to deliver the precision, control and adaptability required for the most demanding medical device applications. These motors enable exact movements for unscrewing threads, adjusting core pulls and fine-tuning speed or force during the molding cycle. With closed-loop feedback, the tooling ensures consistent part quality, protects delicate features and extends tool life. Liefveld explained that the molds the company produces need to be monitored and measured while they are running, with sensors and monitoring capabilities that continuously track temperature and molding injection pressure.
Worker Training
As molds become more complex the challenges in attracting and retaining a skilled workforce also increase. “A lot of kids don’t know about the machining trade,” Liefveld said, noting, “It’s not nearly as popular as it used to be.” To help train the next generation of moldmakers, SyBridge has a five-year apprenticeship program. Liefveld noted, however,
that most participants do not complete the program. “Normally, within six months you kind of figure out whether or not this individual is really fit for it. You have to remember that to be a machinist you have to be pretty good with math, pretty good with your hands and have a high capacity for learning on the fly.” When apprentices come in, he added, they have to be ready to work 10-hour days and be completely dedicated to the program.
Adding to the challenge is that California, for instance, cut funding for off-site classes that helped teach apprentices more about subjects such as trigonometry, geometry and metallurgy. “Once they cut that system out, we had to start teaching those and implement that into their daily routines.” For those who complete the program, the rewards can be compelling. One of the highlights of the apprenticeship program, according to SyBridge, is that former students pass on the skills and habits they have learned to newer students.
They share the tacit knowledge picked up from experienced moldmakers and machinists, like securing workpieces, locating the zero point or starting position on the workpiece, and keeping their work area clean. The focus on cleanliness is especially important for the precision work for which SyBridge is known — because starting with a clean mill ensures debris from previous jobs will not alter tolerances for the next job. Another challenge, Liefveld noted, is the lack of trade schools devoted to moldmaking. The only apprenticeships that are available are through shops with programs.
“And mold shops like us are trying to keep that going because the scary part is if we don’t keep having an influx of young moldmakers coming in, pretty soon we’re going to run out of them.” Despite such challenges, SyBridge continues to grow its production of injection mold tooling that meets the high standards of medical, pharmaceutical and veterinary manufacturing. “We design and manufacture high-precision injection molds, and we sample and validate those tools until the molded parts meet all critical tolerances and functional requirements for production,” Schoelmberger said. “That’s where precision, partnership and performance come together — building the tool right, working closely with the customer and delivering a mold that performs reliably in long-term production.”
