A Guide To Adopting 5-Axis Machining
Modern manufacturing continues to evolve at an unforgiving pace. New technologies emerge constantly, competition is global and customer expectations are higher than ever. Whatever idiom one prefers — dog eat dog world or survival of the fittest — the reality is the same: manufacturers must continuously improve or risk being left behind.
Modern manufacturing continues to evolve at an unforgiving pace. New technologies emerge constantly, competition is global and customer expectations are higher than ever. Whatever idiom one prefers — dog eat dog world or survival of the fittest — the reality is the same: manufacturers must continuously improve or risk being left behind. For many shops, 5-axis machining represents the paradigm shift needed to remain competitive in today’s volatile business climate.
The benefits of adopting 5-axis machining are well established. Fewer setups, shorter and more rigid tooling, improved part processing options and higher process repeatability all contribute to reduced cycle times and better part quality. When paired with capable CAM software, the transition to 5-axis machining becomes manageable rather than disruptive. However, in order to fully realize these advantages, shops must address several practical considerations concerning CAM software.
The Importance of Accurate Simulation Simulation is the foundation of successful 5-axis implementation. Accurate simulation ensures that what is programmed in the digital environment is exactly what will occur on the machine tool once cycle start is initiated. It is important to understand that not all CAM systems simulate the same data. Some simulate pre-posted toolpaths, while others simulate the actual machine G-code.
G-code simulation is the preferred approach because it represents every machine move, including tool changes, accurate rotary motion and transitions to safe positions. Given the wide variety of 5-axis machine kinematics, the complexity introduced by rotary axes cannot be overstated. Manufacturers are trending toward a virtual machine (VM) style system. A VM system brings G-code simulation into play without needing an additional software suite.
As this shift accelerates and technology evolves, trust becomes a critical factor. CAM programmers must have complete confidence that their virtual toolpaths will transition seamlessly to the physical machine. When simulation is accurate and reliable, advanced strategies such as 3+2 indexing and full 5-axis simultaneous machining become empowering tools rather than sources of uncertainty. Making 3+2 Machining Feel Natural Modern CAM software should make 3+2 machining intuitive and efficient.
Often referred to as tilted work plane or plane function, 3+2 machining allows the programmer to orient the tool axis to a desired angle relative to the part model and define a clearance plane. From that point forward, toolpath creation follows the same methodology as traditional 3-axis machining, except that it is applied along a different tool axis. Smooth overlap is a nice addition to 3+2, automatically blending multiple indexes seamlessly. With minimal practice and intuitive software, 3+2 machining quickly becomes second nature and opens new opportunities for efficient part processing.
When the same tool is used across multiple indexed orientations, the CAM system should automatically link all toolpaths. Eliminating unnecessary retracts to safe positions reduces wasted motion, shortens cycle times and keeps the tool engaged in cutting rather than traveling. An NC optimizer module can automatically adjust clearances, link all tool paths and problem solve without any input from the software user. Controlling 5-Axis Simultaneous Motion 5-axis simultaneous programming should never feel cumbersome or overly complex.
Onsrud
Software Savvy
opportunities for efficient part pro- machining scenarios. Each toolpath on surface finish, tool life and cycle cessing. When the same tool is used should be easy to understand, con- time. Yet, restraint is essential. Ex- across multiple indexed orientations, trol and fine-tune to ensure maxi- traneous 5-axis motion increases.
Software Savvy opportunities for efficient part pro- machining scenarios. Each toolpath on surface finish, tool life and cycle cessing. When the same tool is used should be easy to understand, con- time. Yet, restraint is essential. Ex- across multiple indexed orientations, trol and fine-tune to ensure maxi- traneous 5-axis motion increases the CAM system should automati- mum effectiveness on the machine cycle time and often results in un- cally link all toolpaths. Eliminating un- tool. wanted witness marks on finished necessary retracts to safe positions The ability to adjust and manip- surfaces. reduces wasted motion, shortens ulate simultaneous motion is espe- Effective 5-axis programming cycle times and keeps the tool en- cially important when transitioning applies simultaneous motion only gaged in cutting rather than travel- to 5-axis machining. Small refine- where it is truly requi
Visit Onsrud View this placement in the issue recordPrint ads from this magazine
Continue reading
April 2026
CAM software must provide a comprehensive range of toolpaths capable of addressing a wide variety of machining scenarios. Each toolpath should be easy to understand, control and fine-tune to ensure maximum effectiveness on the machine tool. The ability to adjust and manipulate simultaneous motion is especially important when transitioning to 5-axis machining. Small refinements in tool orientation or motion can have a significant impact on surface finish, tool life and cycle time.
At the same time, restraint is essential. Extraneous 5-axis motion increases cycle time and often results in unwanted witness marks on finished surfaces. Effective 5-axis programming applies simultaneous motion only where it is truly required to maintain tool contact or to achieve part accessibility. When to Index vs.
Going Simultaneous One of the most important decisions in 5-axis machining is knowing when indexed machining is sufficient and when full simultaneous motion is necessary. In many cases, indexed 3+2 machining delivers the best balance of simplicity, stability and efficiency. Ideally, CAM software should assist in making these decisions automatically. High-value CAM systems include controls within 5-axis cycles that intelligently designate where 3+2 machining is appropriate and where simultaneous motion is required.
These automated decisions reduce programming effort, minimize risk and consistently produce optimal results with minimal user input.
Digital Accuracy Is Non-Negotiable
In today’s manufacturing environment, complete and accurate digital data is no longer optional. Three-dimensional models should exist for every component involved in the machining process, including stock, fixtures, toolholders, cutting tools and the machine itself. Everything within the machining envelope must be represented digitally and accurately. Attention to detail is critical. Part placement within the stock, stock location within the fixture, jaw spacing, vise placement on the table, toolholder selection and tool stick-out all directly affect simulation accuracy. If any element is incorrect, simulation results become unreliable, regardless of how advanced the CAM software may be.
Collision Avoidance That Reduces Programming Load
Collision avoidance is an area where capable CAM software delivers significant value. In a 3-axis environment, collisions are relatively easy to identify and resolve, often with simple XY adjustments. In 5-axis machining, collision scenarios become exponentially more complex. Advanced CAM systems should handle these situations automatically, tilting the tool to avoid collisions with parts or fixtures while maintaining an optimal cutting path. When collision avoidance is intuitive and automated, programming becomes faster, safer and more reliable. CAM software should reduce the overall programming burden — preventing programming time from becoming a bottleneck in the shop’s production flow.
MFGAxis Discussion
