Machine B7 Without Losing Temper
ASTM alloy A193 grade B7 is a quenched and tempered chromium-molybdenum high-carbon steel used to make fasteners for high-pressure applications.
ASTM alloy A193 grade B7 is a quenched and tempered chromium-molybdenum high-carbon steel used to make fasteners for high-pressure applications. It has a minimum tensile strength of 100,000 psi. This steel can develop a great deal of heat in a machining process. If too much heat is developed in the cut, the material can be hardened by machining.
Not good, since ductility will be lost and the fastener could become unsuitable for its high-pressure application. In this article I will go into the material’s properties and explain machining processes that I have used to work this metal with success. Irecently had a job to deliver 40 B7 full-thread studs 121⁄2" long, 15⁄8"-8 thread, chamfered on both ends with wrench flats cut on one end. Figure 1 shows the part and a chamfer tool I made from a highspeed steel (HSS) tool bit.
(I am fussy about my workmanship, and since these parts were going to the U.S. Navy, well.) The ±0.060" length tolerance could have been hit using the band saw, which has flood coolant, but I don’t like the saw cut surface finish.
Instead, I sawed the parts a little long and faced and chamfered them on a lathe. The quality of a part will be remembered long after the price has been forgotten. If too much heat is developed when machining this material, the chips can be burned black or even get red hot when the chip gets into the metal’s plastic zone. This can return some of the workpiece to the quenched condition, which is harder and less ductile than the B7 condition.
Then, if the quality conremembered long after the price has been forgotten. trol folks at my customer’s shop want to get fussy, they can reject the part. I prefer not to give them an opportunity to get fussy. I want the chips to have the silvery steel color.
Ido three things to prevent overheating the part. 1. I keep the metal removal rate low. 2.
I keep the cutting speed slow. 3. And I use coolant. Iuse Rustlick WS500A, a water-based emulsion, because I have never had problems with skin irritations, like dermatitis, or with rust on the workpiece or machinery.
Greenleafcorporation
XSYTIN®-360 CERAMIC END MILLS
FINALLY—A SOLID CERAMIC END MILL THAT OUTPERFORMS CARBIDE! UP TO 10X HIGHER PRODUCTIVITY Delivers tremendous cost savings! High removal rates on a wide range of materials Capable of significantly increased chip loads versus other ceramic end mills A combination of our strongest ceramic material and a unique cutting geometry.
XSYTIN®-360 CERAMIC END MILLS FINALLY—A SOLID CERAMIC END MILL THAT OUTPERFORMS CARBIDE! UP TO 10X HIGHER PRODUCTIVITY Delivers tremendous cost savings! High removal rates on a wide range of materials Capable of significantly increased chip loads versus other ceramic end mills A combination of our strongest ceramic
Visit Greenleafcorporation View this placement in the issue recordPrint ads from this magazine
Continue reading
April 2026
Plus, water-based coolants remove more heat per unit volume of coolant than oil-based coolants. The ends were faced on a lathe at 220 rpm with a few passes at a about the author Brandt Taylor is owner of Berlin, Massachusetts-based Taylor Engineering, a machine shop and manufacturer of lathe chuck jaws. He can be reached via email at gbrandt taylor@gmail.com.
depth of cut of 0.020" using a TPG carbide insert I ground to have a 15° positive rake on the cutting edge. Remember, more rake, less heat. The lathe I used doesn’t have flood coolant, but I gave the workpiece a squirt from a squeeze bottle.
I also gave the chamfer tool a 15° rake, and that cut was made at 150 rpm. The cutting tools were finished on a cutter grinder with a fine grain diamond wheel for nice sharp edges. Then they went onto a milling machine for the wrench flats. The distance between the flats had to be between 0.99" and 1.00".
That machine does have flood coolant, and I turned it up. The part was clamped in a vise with the flat parallel to the XY plane. The Z datum of 0.0 was set at the face of the flat.
Using a 1⁄ 2"-diameter four-flute HSS endmill at 500 rpm, I made two passes, one at Z 0.110 and one at Z 0.0. The feed rate was set at 12' per minute, and it all worked smoothly with nice surface finish, very little burr and no out-of-spec parts.
Sometimes slower is better and good for business. The customer who gave me this order has been coming back to me for 30 years, and Iget paid well. CTE MachinistCorner.indd 12
MFGAxis Discussion
