Tooling for 2027: test the grade, build the data
Sandvik Coromant’s Bijal Patel discusses machining trials, shared shop-floor knowledge and the value of building a useful machine-data history.
November 17, 2026
A new cutting-tool insert can look much like the one already in the toolholder. For a shop deciding what to invest in next, the important differences may become clear only when the tool starts cutting.
That is one of the messages Bijal Patel, sales enablement manager at Sandvik Coromant, discussed in an interview with Cutting Tool Engineering at IMTS 2026. His advice for shops looking toward 2027 connects three priorities: evaluate tooling advances in the application, collect useful machine data and find out what support suppliers can offer beyond the cutting tool.
Put new grades to the test
Changes in a grade’s composition and technology can be difficult to recognize from an insert’s appearance. Patel encourages shops to investigate those developments rather than assume that a familiar-looking tool offers familiar performance.
The test belongs on the customer’s machine. Evaluating a grade under the shop’s own operating conditions helps establish whether it improves the process and warrants a change.
That approach keeps the purchasing decision tied to the application: what does the new tool do in the work the shop actually needs to perform?
Connect measurements with machining experience
Patel describes technical support as a broader task than recommending an insert. A customer may need help selecting a manufacturing process, meeting a tolerance, diagnosing a change in machining conditions or training operators.
Sensorized tooling can supply another view of the process. Information about loads, vibration and bending moments can help investigate conditions that are difficult to identify through sound, touch or the information displayed by the machine alone.
The measurements also create an opportunity to share experience. A machinist who recognizes a change in the sound of a cut can connect that observation with a chart and explain it to a less-experienced colleague. The chart helps the shop capture and pass along knowledge that might otherwise stay with one person.
Patel sees that connection as a bridge between generations of machinists. Sharing that knowledge is another benefit of gathering process data; it does not replace the judgment of skilled people.
Build the history before you need it
A shop cannot recover months of machine history simply by deciding later that it would be useful. Patel encourages manufacturers to start collecting relevant data even before they have settled on every way they will analyze it.
A record gathered over time can support questions about productivity and machine utilization. A short demonstration or an isolated snapshot cannot provide the same history.
The discussion also touched on MTConnect as a common language for equipment data. The MTConnect standard uses a shared data dictionary and information models to help software interpret manufacturing information from different equipment sources.
Connectivity has become more streamlined, according to Sandvik Coromant. Shops still need to assess their equipment and infrastructure to determine whether additional hardware is needed, although the company says none is required in many cases. Ease of connectivity matters when evaluating a monitoring system for a particular shop.
Match the data to the machine
Manual equipment presents a different monitoring opportunity from a modern machine control. Patel distinguishes a simple indication that a spindle is running from the more detailed information available from newer equipment. Operator comments can add context to the machine data.
Basic operating-state information may help separate running time from downtime. It should not be mistaken for a complete explanation of why a process stopped or how a part was made.
Patel suggests beginning with higher-priority equipment when considering a monitoring project. The goal is to gather information that answers useful questions about each machine and its work.
Ask what else your suppliers can do
For shops planning their next investment, Patel recommends learning more about the capabilities of existing partners. A supplier known for cutting tools may also be able to help with tool inventory, programming, machine monitoring or a broader manufacturing project.
He points to Sandvik Coromant’s work in those areas as examples of how the supplier relationship has expanded. Asking about that support can reveal options a shop has not considered.
Testing a grade, building a machine-data history and connecting measurements with machining experience each give a shop a stronger basis for its next decision. They also give the shop a more specific conversation to have with its suppliers: what can improve this process, and what evidence will show that it has?
