Ceratizit hires tech sales engineer for Midwest office
Ceratizit USA, a manufacturer of standard and custom tooling for the metalworking industry, has enhanced its Midwest presence by hiring an engineer.
September 13, 2023
Steve Smith has been named Technical Sales Engineer. With 42 years of industry experience, Smith serves the company's customers in North Dakota and Minnesota.
Smith specializes in short-hole and deep-hole drilling, turning, milling and advanced tool materials, including ceramic, Cubic Boron Nitride (CBN) and diamond-pcd/" data-glossary-id="141707" data-glossary-teaser="Cutting tool material consisting of natural or synthetic diamond crystals bonded together under high pressure at elevated temperatures. PCD is available as a tip brazed to a carbid…" title="Cutting tool material consisting of natural or synthetic diamond crystals bonded together under high pressure at elevated temperatures. PCD is available as a tip brazed to a carbid…" aria-label="Glossary: polycrystalline diamond (PCD)">Polycrystalline Diamond (PCD).
Along with studies in machining and plastic injection mold making, he attended Anoka Technical College and has completed a variety of factory training programs. Further, Smith's professional leadership is anchored by Kaizen lean strategies that empower production teams to excel.
"Our industry continues to evolve and putting what I know to work for others is when I am at my best," Smith noted. "Helping improve productivity is an investment in my territories' companies, people and communities and I am proud to be part of that investment."
An Army veteran, Smith also volunteered as a Special Olympics coach in several sports.
  • polycrystalline diamond (PCD)
  • cubic boron nitride (CBN)
    Crystal manufactured from boron nitride under high pressure and temperature. Used to cut hard-to-machine ferrous and nickel-base materials up to 70 HRC. Second hardest material aft…
  • drilling
    Operation in which a rotating tool is used to create a round hole in a workpiece. Drilling is normally the first step in machining operations such as boring, reaming, tapping, coun…
  • diamond
    Cubic crystalline form of carbon produced under extreme pressures at elevated temperatures. The hardest natural substance, it has approximately five times the indentation hardness…
  • milling
    Machining operation in which metal or other material is removed by applying power to a rotating cutter. In vertical milling, the cutting tool is mounted vertically on the spindle…
  • turning
    Workpiece is held in a chuck, mounted on a face plate or secured between centers and rotated while a cutting tool, normally a single-point tool, is fed into it along its periphery…
