Cosen Saws showcasing solutions at EASTEC
Cosen is a global leader in band saw manufacturing with an expansive product line and a sales and service network covering all North America. The company is showcasing some of their top saw models and newest cutting solutions at this year's EASTEC show in Springfield, Massachusetts.
May 6, 2025
The show will run May 13-15, 2025, with Cosen presenting a diverse assortment of cutting solutions at booth 2114.
With over a decade of exhibiting at Eastec, Cosen is representing brands. Cosen has continued to push the standards of sawing and deliver cutting-edge solutions designed to meet the diverse needs of numerous industries such as automotive, aerospace, steel construction, and more.
At this year's Eastec, Cosen will showcase four different saw models, each of which are designed to enhance productivity, accuracy, and safety. Visitors to the booth will have the opportunity to witness these cutting machines up close and in person, with experts on hand to answer questions and provide additional insights into the company and its solutions.
Cosen Saws will be showcasing the following products at Booth 2114:
  • MH-1018JA: Semi-Automatic, Scissor Style Band Saw - Capacity: 9" x 16.5"
  • C-260NC: Fully Automatic, Scissor Style Band Saw - Capacity: 10.2" x 11.8"
  • V-1822: Semi-Automatic, Manual Miter Vertical Tilt-Frame Band Saw - Capacity: 18" x 22"
  • 1/2 SH-500M: Semi-Automatic, Scissor Style Miter Cutting Band Saw - Capacity: 11" x 17.3"
SH-510LDMB
  • sawing
    Machining operation in which a powered machine, usually equipped with a blade having milled or ground teeth, is used to part material (cutoff) or give it a new shape (contour bands…
  • steel
    Basically, iron in combination with carbon and other elements. There are five major groups of steels: carbon steel, alloy steel, stainless steel, tool steel and maraging steel.
