Emuge to host 5-axis machining event with GibbsCAM and MatsuuraUSA
Emuge-Franken USA, a manufacturer of high-performance taps, thread mills, end mills, drills, gages, other rotary tools, and precision clamping solutions, is collaborating with GibbsCAM and Matsuura to host a 5-Axis Machining Live Demo Event. The event takes place on May 21, 2026, from 10:00 a.m. to 2:00 p.m. at the Emuge-Franken Technology Center, 1800 Century Drive, West Boylston, Massachusetts.
May 13, 2026
The event takes place on May 21, 2026, from 10:00 a.m. to 2:00 p.m. at the Emuge-Franken Technology Center, 1800 Century Drive, West Boylston, Massachusetts. Designed for CNC programmers, machinists, and manufacturers considering the move from 3-Axis to 5-Axis, this event will focus on practical strategies to simplify 5-axis machining and improve productivity.
Demonstrations will take place on the Matsuura MX-330 PC10, highlighting how modern 5-Axis platforms with pallet systems can help shops keep spindles running longer, reduce idle time between jobs, and better manage multiple parts or operations, especially in high-mix, low-volume production environments. GibbsCAM will demonstrate how intuitive 5-axis programming and full machine simulation help simplify complex machining workflows and reduce programming time.
Attendees will also see the new Emuge EvoGrip precision clamping system in action, demonstrating industry-leading clamping force of up to 75 kN, fast changeovers that reduce lead times, and repeat positioning with +-0.01 mm accuracy, designed to improve accuracy, stability, and process security in demanding machining applications.
Complimentary food and beverages will be served at the event.
For more information and to register for the event, click here.
Scroll for the next story
