Filter technology perfectly cleans oils
As shown at IMTS this month, only through the use of extremely clean grinding oils can high-quality tools be ground economically and reliably against increasingly tight tolerance requirements.
September 27, 2022
At IMTS this month, Vomat said its filter systems are perfect for the filtration of microparticles in lubricants used in processes such as grinding, honing, lapping and eroding.
The company offers high-performance backflushing cartridge filter systems with highly accurate temperature control, automatically controlled sludge sedimentation, and online monitoring to avoid any shutdowns of the filtration system during production.
filtration tehnology
A HSS pre-filter can be easily retrofitted into any VOMATsystem due to the modular machine concept. The VOMAT filtration systems range includes stand-alone and whole plant systems and is designed for easy adaptability to customer-specific requirements. With an array of optional add-on equipment, you can expand the systems to ever-changing needs in terms of capacity or product quality.
Steven Lowery, executive vice president for Oelheld, the official reseller of Vomat Filtration Systems in North America, said: "The exacting requirements of the metal machining industry in North America regarding quality and cost-effectiveness can be met only through high-performance machine technology and precision tools. This also means customized troubleshooting, flexible services, and speedy deliveries. To achieve this, we need to be close to our customers. We meet these high standards. With Vomat ultrafine filtration technology, they have a wide range of high-performance filters at their disposal, which promise productivity, optimize the quality and ultimately increase the profit."
  • grinding
    Machining operation in which material is removed from the workpiece by a powered abrasive wheel, stone, belt, paste, sheet, compound, slurry, etc. Takes various forms: surface grin…
  • lapping
    Finishing operation in which a loose, fine-grain abrasive in a liquid medium abrades material. Extremely accurate process that corrects minor shape imperfections, refines surface f…
