New bolt and nut caps provide protection and a finished appearance
MOCAP has added a new protective solution to its product catalog: its BNCD Series of Domed Bolt and Nut Caps. Designed to provide both protection and a finished appearance, the company says these caps are "ideal for covering exposed bolt and nut heads in a variety of industrial, commercial, and consumer applications."
June 1, 2025
Molded in durable black polyethylene plastic, these Domed Caps are designed to snap securely over standard hex nuts and bolts, shielding them from dirt, moisture, and corrosion while also reducing the risk of injury from exposed hardware. Their domed profile enhances appearance and safety, making them suitable for use in environments where aesthetics and protection are both priorities, including machinery, outdoor structures, automotive applications, and more.MOCAP
MOCAP, which is a global leader in the manufacturing of plastic and rubber product protection, masking products, finishing components and packaging, said its new Domed Bolt and Nut Caps are available to fit a wide range of standard hex bolt and nut sizes, and, like all MOCAP products, they are in stock and available for immediate shipment in box, minipack, and micropack quantities.
Order online before 2 p.m. CST for same-day shipping. To request free samples or for pricing, contact the sales department at:
MOCAP
409 Parkway Drive
Park Hills, MO 63601
Ph: (800) 633-6775 or (314) 543-4100
Fax: (314) 543-4111
www.mocap.com
[email protected]
  • corrosion
    Chemical or electrochemical reaction between a material, usually a metal, and its environment that produces a deterioration of the material and its properties.
  • finishing
    Any of many different processes employed for surface, edge and corner preparation, as well as conditioning, cleaning and coating. In machining, usually constitutes a final operatio…
