PTG Holroyd displays large-capacity helical profile grinding machine
PTG Holroyd displays large-capacity helical profile grinding-machine/" data-glossary-id="141847" data-glossary-teaser="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" title="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" aria-label="Glossary: grinding machine">grinding machine
PTG Holroyd hosted an event at its Rochdale, United Kingdom, facility during which it gavew a sneak preview of its soon-to-be-launched, large-capacity HG500 ultra-high-performance helical profile grinding machine,
June 12, 2024
PTG Holroyd hosted an event at its Rochdale, United Kingdom, facility during which it gavew a sneak preview of its soon-to-be-launched, large-capacity HG500 ultra-high-performance helical profile grinding-machine/" data-glossary-id="141847" data-glossary-teaser="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" title="Powers a grinding wheel or other abrasive tool for the purpose of removing metal and finishing workpieces to close tolerances. Provides smooth, square, parallel and accurate workpi…" aria-label="Glossary: grinding machine">grinding machine,
Held at PTG Holroyd's Rochdale-based machine tool technology center on May 22, the company hosted the quarterly regional meeting of The Advanced Machinery & Productivity Institute (AMPI)
The event included networking opportunities and an update on the institute's flagship industry and academic-led projects that support manufacturers in the development of world-class machine tool technologies.
More than 30 delegates commenced a tour of PTG Holroyd's production facilities – the highlight being a demonstration of the company's new HG500 helical rotor CNC grinding machine.
"Following the recent, highly successful launch of our smaller HG350 gear grinding center - the first UK machine tool to use Siemens Sinumetrik One future-proof CNC - we realized that a very real need also existed for a new large-capacity helical rotor grinding machine," said PTG Holroyd's Engineering Director, Paul Hinchliffe.
"As you can imagine, however, the challenges involved in developing two new machine tools in close succession are considerable, particularly for a UK-based manufacturer operating in the vastly competitive global sector," he adds. "We were therefore delighted that after reviewing the impressive environmental credentials and performance capabilities of our proposed new HG500 model, AMPI agreed to help support us during the development stages of the machine. As a result, we will be able to launch the HG500 much sooner than would have otherwise been possible."
Full details of PTG Holroyd's new HG500 ultra-high-performance CNC helical profile grinding machine will be available when the machine is officially launched later this year. Utilizing Siemens CNC system, integrated with the Holroyd Profile Management System (HPMS), the HG500 will accommodate workpieces of up to 500 mm in diameter and up to 1,500 kg in weight. Rapid setup of same component batches will be provided via the machine's data and program files. Operating with two diamond dressing disks, the CNC-controlled diamond or other tool. The process also exposes unused, sharp abrasive points. See loa…" title="Removal of undesirable materials from “loaded” grinding wheels using a single- or multi-point diamond or other tool. The process also exposes unused, sharp abrasive points. See loa…" aria-label="Glossary: dressing">dressing unit will provide automatic wheel profile calculation for each dress cycle along with programmable dressing feed rates for roughing and finishing cycles. While in-cycle profile measurement and correction will be delivered using Renishaw's high-speed, high-accuracy OMP60 scanning probe with Sprint technology.
  • grinding machine
  • finishing
    Any of many different processes employed for surface, edge and corner preparation, as well as conditioning, cleaning and coating. In machining, usually constitutes a final operatio…
  • dressing
  • grinding
    Machining operation in which material is removed from the workpiece by a powered abrasive wheel, stone, belt, paste, sheet, compound, slurry, etc. Takes various forms: surface grin…
  • diamond
    Cubic crystalline form of carbon produced under extreme pressures at elevated temperatures. The hardest natural substance, it has approximately five times the indentation hardness…
