Tap Magic H2OX NC metal cutting fluid
Tap Magic H2OX™ NC is an excellent metal cutting fluid formulated to provide lubricity while eliminating the sticky messy film associated with heavy oil products. It is a semi-synthetic product engineered to provide great performance in a variety of areas. It is safe and operator friendly, meeting regulations of all 50 states in the US and most regions abroad.
Sponsored ContentPresented by Tap Magic / The Steco Corporation
September 9, 2026
Designed for non-ferrous metals, this coolant works especially well for aerospace or military applications that do not allow chlorinated lubricants. It provides a superior finish on aluminum, brass, and copper parts while keeping expensive tooling sharper longer. This is a fully formulated product, rarely requiring tank side additives for various issues that might be common in circulating systems, such as corrosion, foaming, separation (film build up), etc.
Tap Magic H2OX™ NC supports all metalworking applications including grinding, sawing, milling, boring, and reaming. Tooling for metalworking is getting better all the time, but that is driving costs higher.  Sawblades, inserts, endmills, abrasives, taps, etc. can come in a variety of coatings to match specific applications. Getting these tools to last through more cuts makes premium lubrication critical. Tap Magic H2OX™ NC is a multi-faceted fluid that checks all the boxes for a one stop solution. It can be used with any water-based metal cutting system to provide the following benefits:
Extended Tool Life (coated or uncoated tooling) – while today’s coated tools last longer than uncoated, professionals still want the most life they can get and a premium coolant provides the lubricity to achieve this goal.
Long Sump Life (low bacterial growth) – shops make money by making parts, not changing out their sumps. Longer times between change outs means more time being productive and satisfying orders.
Low Skin Irritation Formulation – today’s modern machines do a great job of containing the coolant, but let’s face it, you’re still going to get it on your hands and arms. A mild solution is a must in today’s fast-paced work environment.
Resistant to Residue or Film Build Up – the best coolants contain additives to maintain low surface tension and keep their emulsions tight.
Corrosion Resistant – water, additives, and metals don’t always go together when it comes to staining or corrosion. Parts that can be washed off easily and show no signs of discoloration make for happy customers.
Low Foam Characteristics – foam indicates air in the water and that accelerates bacterial growth, decreasing sump life quickly. If the coolant already has a good defoamer included, there is no need to add this product tank side.
You’ve trusted Tap Magic oil-based products for decades, so we spent years perfecting a water-soluble product that is worthy of the Tap Magic name. If you want more life out of your tooling and happy customers, try Tap Magic H2OX™ NC today. It is sold in packages built to match your operation, from gallon bottles to 275-gallon totes.
Author:
Ken Gaines, President, The Steco Corporation
Ken has worked for The Steco Corporation for over a decade, expanding the Tap Magic line and continuing to keep up with new advances in chemistry to provide the best value products available. Tap Magic is one of the most recognized names in Industrial Supply and The Steco Corporation will celebrate 75 years in business in 2028.
Tap Magic H2OX NC five-gallon container
Tap Magic H2OX NC gallon container
Scroll for the next story
