Tap Magic Waxx Stick Solid Lubricant
Tap Magic Waxx Stick puts a soft, waxy solid lubricant directly on tooling for grinding, sawing, finishing and other metalworking applications where liquid cutting fluids cannot be used.
Tap Magic Division of the Steco Corporation
Liquid lubricants can’t be used to cut metal in some applications for a variety of reasons. The Steco Corporation has developed one of their world-class lubricants into a solid form for use in these situations – Tap Magic Waxx Stick. This lubricant stays with your tooling due to its soft waxy consistency but also provides maximum protection through an engineered blend of additives. This product is perfect for grinding, sawing, finishing, or any other metal working application.
Tap Magic Waxx Stick provides the modern machinist with several advantages:
- Easy to use solid form in grease tube
- Increased tool life
- Saves time by reducing cut time
- Easy clean-up
If you need a good lubricant but can’t use a liquid cutting fluid, use Tap Magic Waxx Stick and impress your customers. For more information, please visit our website at www.tapmagic.com.
Sincerely,
Ken Gaines, President
