Unisig to focus on deep-hole gundrilling at Eastec
Unisig to focus on deep-hole Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank." title="Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank." aria-label="Glossary: gundrilling">gundrilling at Eastec
At Eastec, Unisig plans to showcase automation that it says will take "deep-hole drilling machine efficiency and productivity to new levels."
March 2, 2023
The trade show is scheduled for May 16-18, in West Springfield, Massachusetts.
Company experts will be on hand to discuss how engineered automation is routinely included in deep-hole drilling machine cells and can be machine mounted or used to combine multiple machines or operations.
UNISIG is experienced in developing safe and effective standard automation that encompasses specialized solutions to fit the needs of particular production demands, applications, or facilities – enabling shops to make the most of their UNISIG deep-hole drilling machines. To accomplish this, the company engineers three types of automation solutions – those that are flexible, machine mounted or custom designed.
Flexible automation solutions are versatile features that can be integrated into the machine design, or designed independently, to automate the operation of a single machine, or combine multiple machines into an automated cell. Flexible automation encompasses robots, part-tray-handling conveyors, pallet changers and servo-driven gantries.
Programmable smart conveyors and walking beam loading systems are two examples of UNISIG's machine-mounted automation solutions for part loading and handling. The company engineers these solutions into a machine's design so that they function integrally with it.
For more extensive automation requirements, UNISIG will program and integrate custom automation such as pick-and-place systems, heavy bar loaders, and bulk feeders into a deep-hole drilling process. These custom-engineered solutions are optimized to fulfill a shop's production, application, budget and facility requirements.
  • gundrilling
  • drilling
    Operation in which a rotating tool is used to create a round hole in a workpiece. Drilling is normally the first step in machining operations such as boring, reaming, tapping, coun…
  • loading
    In grinding, the wheel’s tendency to accumulate workpiece material between its abrasive points. In milling, drilling and other operations, excessive packing of chips in cutter flut…
