Artificial Intelligence Suite
DataProphet announced the launch of its comprehensive Artificial Intelligence Suite to improve production quality and reduce defects for Industry 4.0. Through a combination of DataProphet TRANSFORM, DataProphet PRESCRIBE and DataProphet INSPECT, customers can expect to see a significant, practical, impact on the factory floor.
DataProphet announced the launch of its comprehensive Artificial Intelligence Suite to improve production quality and reduce defects for Industry 4.0. Through a combination of DataProphet TRANSFORM, DataProphet PRESCRIBE and DataProphet INSPECT, customers can expect to see a significant, practical, impact on the factory floor. DataProphet's solutions are built to be adapted and integrated into any environment, minimizing process change.
Unique deep learning solution that can prescribe optimum plant control parameters, frequently reducing the cost of non-quality by more than 50 percent, through a customized single model approach, while taking into account higher order effects.
DataProphet INSPECT
This cutting-edge machine vision system, which, unlike other inspection solution, does not use template matching to detect defects but instead relies on proven machine learning algorithms to flag manufacturing defects.
AI advisory and consulting services supporting digital transformation in manufacturing. Assists data-heavy manufacturers to discover insights and predictive capabilities hidden in their data to produce quantifiable results.
"DataProphet understands manufacturing. Our experts in digital transformation can take plant operations from zero to AI," said Michael Grant, CTO at DataProphet. "We offer the most comprehensive machine learning solution and data science expertise in manufacturing for Industry 4.0."
DataProphet's Artificial Intelligence Suite is available immediately and can easily be customized if required. Each module is offered as a stand-alone solution or can be combined to create synergies and further improve plant efficiency.
