E-Z Tec 9100 Metal Detector
Eriez is now stocking the E-Z Tec 9100 Metal Detector.
Eriez is now stocking the E-Z Tec 9100 Metal Detector. When metal damages expensive equipment or shuts down a process or contaminates a product, the boss often says, "fix the problem now" — and Eriez can help. The company's most popular sizes, the 9100-45, 70, 100 and 120 are ready for shipment within a week or less.
These metal separators, which are popular in the plastics and rubber industries, have features that include:
Superior sensitivity to all metals using Eriez balanced coil technology,
Adjustable, quick acting, air powered reject mechanism,
Easy installation in gravity flow applications in a compact design,
Jacob Fittings are standard on the discharge outlets for simple and secure connections,
No calibration necessary and the sensitivity is adjustable,
One fault relay and one detect or output relay,
Single circuit board with self-monitoring electronics,
NEMA 12 painted steel enclosure, air filter, air regulator and water bleeder,
CE conformance to EMC and Safety regulations,
One year warranty.
This compact metal detector is designed for installation in free fall or gravity fed applications, especially where space is limited. The E-Z Tec 9100 incorporates balanced coil technology and offers a higher sensitivity compared to other metal separators. It ensures detection and rejection of very small ferrous, nonferrous and stainless steel metals. The E-Z Tec 9100 offers a high-speed, air operated rejection system to minimize good product waste. This state-of-the-art metal detector/separator is used to reject metal contaminated material, or as a final quality check device.
