Edge X-5 5-axis Water Jet System
Waterjet systems manufacturer Jet Edge Inc. introduces the EDGE X-5 5-axis water jet system.
Waterjet systems manufacturer Jet Edge Inc. introduces the EDGE X-5 5-axis water jet system. The Jet Edge EDGE X-5 5-axis waterjet system cuts complex taper-free and 3D parts from virtually any material. Featuring Jet Edge's Permalign EDGE technology, the EDGE X-5 is capable of cutting chamfers, weld bevels and sophisticated 3D parts such as impeller blades.
The EDGE X-5 features an industrial PC controller designed specifically for 5-axis waterjet cutting. The AquaVision Di Controller's open architecture design gives operators the freedom to fine-tune programs from any CAD/CAM/nesting software, utilizing standard G and M code. The system's Intelligent Work Envelope automatically adjusts depending on the angle of the cut to protect the operator, material, and system components.
The EDGE X-5 is designed to provide years of dependable service in harsh industrial environments, according to the company. Its rock-solid design separates the motion system from the catcher tank, eliminating vibration and ensuring maximum part quality. It is ball-screw driven for optimal precision and features direct-couple AC brushless digital servo motors and single or double carriages. Critical bearing components are protected by heavy metal covers with brush seals and positive air pressure.
The EDGE X-5 is available in a range of sizes, from 5"x5" (1525mm x 1525mm) to 24"x13" (7515mm x 3365mm). It is powered by a Jet Edge waterjet pump. Jet Edge offers the widest selection of pumps in the industry; 30-200hp (22-149kw), 60,000-90,000 psi (4100-6200 bar) hydraulic intensifier and direct drive pumps are available.
