Emerald Waterjet Cutting Machines
WARDJet has introduced the Emerald 0606 (2' x 2') and the Emerald 0612 (2' x 4') to its existing Emerald Series Line of low-cost, American-made waterjets.
January 1, 2014
The smallest waterjet ever manufactured by WARDJet, the Emerald 0606 is designed to offer all the quality of a large, expensive waterjet cutting system at a reduced size and cost. Because of its rigid, sturdy tank design, the Emerald 0606 is capable of handling 12" thick stainless steel just as easily as a 2" sheet of foam.
The Emerald 0606 offers a cutting envelope of 2' by 2' and 12' of Z-travel and is designed with ballscrew drives and a cantilever-style arm. This short-travel, cantilever architecture effectively balances the reduced machine footprint and number of moving parts of the Emerald 0606, while maximizing cutting envelope and maintaining overall stiffness.
The Emerald 0612 offers double the cutting envelope at 2' by 4'. The cantilever-style arm is ballscrew driven, the tank is beefed up for extra support, and the overall footprint is small. The Emerald 0612 offers the advantage of indexing sheets of unlimited length from front to back — standard 4' by 8' sheets of material up to 2" thick can be cut with greater convenience.
  • waterjet cutting
    Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound…
