Flush cutting system for heavy industrial applications
The MAXPRO200 FlushCut consumables from Hypertherm Associates were designed for thick‑metal removal applications. FlushCut allows operators to remove attachments, including pad eyes, D-rings, lifting lugs, and alignment fixtures, up to 90 percent faster than traditional oxyfuel methods, while reducing grinding by up to 40 percent without damaging the base material, the company said.
Liquid-cooled consumables, the company added, enable high cutting capacity up to 64 mm (2.5 inches) thick mild steel with long consumable life.
Hypertherm´s MAXPRO200 plasma cutters support handheld torches, mechanized carriages and tractors, X Y cutting tables, and robotic cutting systems, delivering flexibility across a wide range of applications.
The intuitive FlushCut drag cutting feature simplifies training and helps address skilled labor challenges while maintaining consistent, high quality results. The design also improves operator comfort, reduces noise, and lessens fume exposure compared to traditional cutting methods such as oxyfuel and carbon arc gouging.
