GN 113.7 Ball Lock Pins
J.W. Winco Inc. announced it now offersseries GN 113.7 Ball Lock Pins with Plastic T-Handle, in metric sizes.
September 13, 2012
J.W. Winco Inc. announced it now offersseries GN 113.7 Ball Lock Pins with Plastic T-Handle, in metric sizes. These ball lock pins are used for rapid connecting and securing of components or work pieces. A typical application is locating pins that have to be regularly moved in and out of position. By depressing the spring-loaded push button, the two balls are freed, and by releasing the push button the balls are locked.
These RoHS-compliant ball lock pins have a T-handle of black plastic (Polyamide PA). The pin is stainless steel, European Standard No. 1.4305 (American Standard No. 303). Balls are stainless steel, European Standard No. 1.3541, and spring is stainless steel, European Standard No. 1.4565. A broad range of handle sizes and pin lengths are offered.
