Intelli-MAX Software Suite for JetMachining Centers
OMAX Corp. expanded its Intelli-MAX software suite for OMAX JetMachining Centers with the release of Intelli-MAX 21.
September 1, 2014
OMAX Corp. expanded its Intelli-MAX software suite for OMAX JetMachining Centers with the release of Intelli-MAX 21. The latest version, with a new fourth generation cutting model, not only optimizes tool paths automatically, it gives users precise predictability as to cutting speeds, taper, jet lag and other abrasivejet factors of those particular tool paths. All of which takes abrasive waterjet cutting to a high level of speed and performance.
The cutting model within Intelli-MAX 21 builds upon years of real-world abrasive waterjet data accumulated through OMAX's first- and second-generation equation-based cutting models as well as from the massive data set of its third-generation model. The result is a cutting model that provides precise process and machine behavior predictions.
According to Carl Olsen, lead software engineer for OMAX, this new cutting model offers improved cutting performance across the board. "With version 21, OMAX abrasive waterjet users gain the highest level of control, most uniform cutting and surface finishes, extended ranges of machinability and the best waterjet cutting precision, speed and repeatability on the market."
Intelli-MAX Software updates bring performance enhancements to the company's broad range of machine accessories. With version 21, Tilt-A-Jet users experience increased speed and accuracy when machining inside corners and small radii, especially in thick materials. Based on customer feedback, Intelli-MAX 21 includes AutoPath command improvements, better import capabilities for DXF/DWG and PDF files, as well as enhanced memory for the 3D Path Editor. The software requires minimal operator training and makes it easy for users to quickly create precision 2D and 3D parts and at a low cost.
"Whether it involves better file importing or expanding our parametric shape library for enhanced 3D cutting, we continuously update and improve our software so we can effectively support the diverse and changing needs of our customers," said Olsen. "Intelli-MAX updates are free to OMAX machine owners for as long as they own their equipment."
  • waterjet cutting
    Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound…
  • machinability
    The relative ease of machining metals and alloys.
