iP60-150 Waterjet Pump
Jet Edge Inc. iintroduced the new 150hp, 60,000 psi iP60-150 waterjet intensifier pump.
May 1, 2011
Jet Edge Inc. iintroduced the new 150hp, 60,000 psi iP60-150 waterjet intensifier pump. The Jet Edge iP60-150 water jet pump is capable of producing up to 3 gallons per minute (11.4 l/min) of ultra-high pressure water for precision water jet cutting and UHP surface preparation applications. It supports orifices up to .025" (.64mm) and features dual intensifier systems.
The iP60-150 includes numerous design improvements, including an efficient kidney loop hydraulic cooling and filtration system, an anti-corrosive interior coated hydraulic reservoir, easy-to-remove lift-off covers, and touch-screen controls. The pump's motor drive assembly has been mounted on an isolation system to reduce noise and vibration.
Like all Jet Edge waterjet pumps, the iP60-150 features Jet Edge's reliable tie-rod design. This design has no threaded cylinder, no threaded end caps, and no threaded hydraulic cylinder, making it less prone to cracking than threaded designs. Jet Edge water jet pumps feature hydraulic accumulators, which reduce wear on the hydraulic pump, and a rugged hydraulic center section which incorporates high-duty cycle-rated piston seal and wear rings. Jet Edge's hydraulic systems have a 4,000-hour warranty. Jet Edge water jet pumps also feature attenuators which smooth pressure fluctuations and deliver a constant and steady stream of UHP water to the cutting tool, ensuring optimal cut quality.
