J- and L-Series Waterjet Cutting Systems
WARDJet Inc. has designed two high-speed, high-production, American made waterjets: the J-Series and L-Series.
July 13, 2013
WARDJet Inc. has designed two high-speed, high-production, American made waterjets: the J-Series and L-Series. These reliable waterjet cutting systems are paired with innovative solutions for material handling and automation to provide a competitive edge in the waterjet industry.
The J-Series is WARDJet's low-cost water-only waterjet. Using belt drive technology, the J-Series waterjets can cut at speeds of 2500 ipm with an acceleration and deceleration rate of 0.2m/s2. J-Series waterjets are ideal for companies looking to cut high volumes of parts where margins are low and tolerances are not as demanding. Also, the J-Series can accommodate the addition of material handling solutions such as loading/off-loading tables, as well as optical sensors to control chain feed tables or pinch feed rollers. The modular design of the J-Series waterjet makes it possible for small design changes to turn a standard waterjet system into a machine designed specifically for your application.
The L-Series is the fastest cutting waterjet offered at WARDJet. It uses a linear motion drive system, renowned for its excellent accuracies, placement repeatability, and reliability allowing customers to cut at incredible speeds of 7,000 ipm with an acceleration and deceleration rate of 1m/s2. The frame of the L-Series is made of thick-walled steel tubing to be able to accommodate multiple 5-axis cutting heads.
  • waterjet cutting
    Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound…
