JS Style Chipbreaker Insert
Tungaloy is expanding its MiniForce-Turn, an economical turning tool series, to include the -JS style chipbreaker insert promising efficient chip control and machining stability.
February 12, 2019
MiniForce-Turn features an innovative double-sided positive insert and unique seat interface for secure location, which is designed to provide free cutting as standard single-sided positive inserts do, while enhancing maximum stability and tool economy.
The new -JS style chipbreaker is designed to promote effective chip control when machining small parts. Its cutting edge incorporates a large inclination angle, which helps produce smooth chip flow and a light cutting condition. This geometry virtually eliminates chip nests, decreasing part scraps and machine downtime, while improving finishing quality. The -JS chipbreaker complements the existing MiniForce-Turn chipbreaker offering and broadens the application range in small part machining. The new chipbreaker is available on six-cornered WXGU0403 inserts and four-cornered DXGU0703 and VXGU09T2 inserts.
At a glance:
Innovative double-sided positive inserts with a cutting action as free as standard positive insert
The cutting edge designed with a large inclination angle to facilitate smooth chip control and light cutting action
Innovative seat interface for secure insert retention and machining stability
  • inclination angle
    Angle that the cutter edge makes with a plane that is perpendicular to the direction of tool travel. Determines the direction the chip curls.
  • chipbreaker
