MasterSil 910 Med Acetoxy Silicone System
Master Bond MasterSil 910Med is a one part acetoxy type silicone system that meets USP Class VI specifications for biocompatibility and ISO 10993-5 testing for cytotoxicity. This translucent paste has superior chemical resistance and also withstands many sterilization methods, including liquid sterilants, gamma radiation and EtO.
As a silicone, MasterSil 910Med delivers high flexibility and has an elongation of 400 to 600 percent. This imparts reliable thermal cycling and mechanical shock resistance. Bond strength to metals, composites, glass ceramics, rubbers, plastics and other silicone substrates is excellent. It is serviceable over the broad temperature range of -75° F to +400° F. It is also a competent electrical insulator with a volume resistivity of greater than 1015 ohm-cm.
Easy to handle, this single-component system cures at room temperature and has a tack free time of 10 to 20 minutes. Curing is based on the humidity level, where the higher the humidity, the faster the cure. Additionally, thinner sections cure more quickly than thicker ones.
MasterSil 910Med is available in 80 gram tubes and has a shelf life of 6 months.
