MN 130 Series
J.W. Winco Inc. announced it offers MN 130 series Pneumatic Power Clamps from Misati S.L. The RoHS-compliant, metric size clamps are made of C45 hardened steel with a black oxide finish. They have a maximum pressure of 10 bar and work pressure of 6 bar. These patented, smaller profile, high clamping force, reduced air consumption, super-efficient clamps are a revolutionary approach for applications in assembly, verification, handling, robotics, machining, welding, etc. Having a reduced size, these clamps achieve higher holding forces than other clamping options. The accompanying standard accessories can adapt the clamps to most all applications, such as molded, cast or machined surfaces, caustic environments and sensor requirements.
  • black oxide
    black oxide
    Black finish on a metal produced by immersing it in hot oxidizing salts or salt solutions.
  • robotics
    robotics
