New Version of HALCON 18.11 Software
MVTec Software GmbH will release the new version 18.11 of its standard software HALCON on Nov. 30, 2018. Many highlights in the new release are the result of MVTec's ongoing development of AI technologies, such as deep learning and convolutional neural networks (CNNs). For example, object-, feature-, or error classes trained with deep learning can now be segmented with pixel accuracy.
October 2, 2018
Similar to classification, segmentation can be performed on a GPU as well as a CPU. MVTec provides pretrained networks based on millions of royalty-free images for training the required network. Customers can train new objects more easily, since they do not require hundreds of thousands of their own application images. This paves the way for an entirely new range of applications, which previously could not be realized, or only with significant programming effort. As the images contained are free of third-party rights, they can be used in commercial applications without reservations.
Another helpful feature of the new HALCON version is the localization of trained object-, feature-, or error classes in an image – also with the help of highly-developed deep learning algorithms. In contrast to pixel-precise semantic segmentation, the sought-after objects are each marked in the image by a surrounding rectangle (a so-called bounding box). This leads to new possible applications in the area of quality control. A wide range of complex machine vision localization tasks can be re-evaluated and performed with far less effort than conventional methods. The object detection inference also runs on both a GPU and a CPU, which offers significant advantages for use in industrial environments. Pretrained networks are likewise available to make it easier to "train" new objects. Furthermore, this feature can be used to reliably identify and thus count objects that touch each other or partially overlap.
Moreover, HALCON 18.11 provides a crucial advantage for the world of embedded vision. The new release now also runs on the increasingly popular 64-bit Arm architecture right out of the box.
A USB3 Vision interface for both 32 and 64 bit is included as well. A further improvement is that the reading of data codes has been optimized and made more flexible. For example, the ECC200 data code reader is much faster and capable of reading codes with missing or damaged/disrupted "quiet zones." In addition, codes against complex backgrounds can be found and read faster and more robustly.
Developers too will benefit from the new release. HDevelop, HALCON's integrated development environment, now displays detailed information about important handle variables, which is very helpful for debugging: It allows users to easily identify and check the current features of complex data structures at a glance. Double-clicking on a handle variable displays all the assigned parameters and their current settings. Even complex parameters with multiple key-value pairs, such as the camera parameters in 3D shape-based matching, can be easily checked.
With the so-called "dictionaries," HALCON 18.11 also provides a new data structure for conveniently managing complex data. For example, different data types, such as images, ROIs, and parameter settings, can be grouped into a single dictionary. This helps to structure programs when, for example, passing many parameters to a procedure. Besides, data contained in dictionaries can be easily shared with experts for offline debugging. Dictionaries can furthermore be read in the widely used JSON (JavaScript Object Notation) data exchange format, allowing for a more efficient integration of data from different sources into HALCON.
The field bus connection is another useful feature for developers. Thanks to the Hilscher CifX interface, HALCON can communicate with almost all industrial field bus protocols. Profibus, ProfiNet, and Ethernet/IP, among others, are supported.
Over this, HALCON 18.11 fully supports UTF-8 encoding, which means that the software can be easily used in multiple languages simultaneously. This particularly benefits companies that operate across different countries, or that have employees working in different languages. As a result, Western alphabets and Asian characters are now displayed in the same encoding and no longer have to be converted from one to another, reducing error rates.
The new HALCON 18.11 release comes in a Steady edition and a Progress edition. While the latter is available by subscription and has a 6-month release cycle, the Steady version is offered for regular purchase with a release cycle of 2 years.
"With the new version 18.11, we are raising our proven HALCON standard machine vision software to a new level. In particular, the current version focuses on the promising topics of deep learning and embedded vision. The numerous new and improved functions also enable developers to significantly speed up their daily work. Therefore HALCON 18.11 is absolutely essential for all machine vision professionals," comments Johannes Hiltner, product manager HALCON at MVTec.
