Series GN 6322 Workholding Pins
May 13, 2013
J.W. Winco Inc. announced it offers series GN 6322 Workholding Pins, in metric sizes. These RoHS-compliant pins are inserted into bores for positioning, with the ball-type shoulder facilitating the insertion into the bore. The pins are tempered, hardened steel. Diameters range from 10 to 25mm.
Type B is cylindrical in shape, while Type C has flattened sides on the pin. The flattened design of Type C provides tolerance for the spacing of the two bores. Another application of this design is to fix parts to be positioned in one direction only.
  • tolerance
    tolerance
Sponsored Content
