Solar Manufacturing ships 12-bar bottom-loading vacuum furnace
Solar Manufacturing has shipped a 12-bar vertical bottom-loading vacuum furnace for thermal processing applications. Its work zone measures 6 ft. in diameter by 6 ft. high and accommodates loads up to 6,000 lb.
The furnace can operate at vacuum levels of 10⁻⁵ Torr or under positive-pressure inert gas. Dual pumping systems include 35-in. Agilent diffusion pumps, booster pumps and roughing pumps.
Maximum operating temperature is 2,400°F. The company specifies temperature uniformity within ±10°F from 1,000°F to 2,250°F, whether processing in high vacuum, partial-pressure inert gas or positive-pressure gas atmospheres.
A 600-hp gas cooling motor and a 12-bar recirculating gas cooling system provide rapid, controlled cooling. The company announced the shipment on November 16, 2026.
Source: Solar Manufacturing news release. Edited by CTE staff.
